Deselect by angle
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello all,
please any one can help deselect the nodes or elements by feature angle through scripts.
Welcome!
Answers
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited December 2016
    A screenshot to better understand your question?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hello Nguyen-dai,
    I can able to select the elements with in the some feature angle ( ex 50 degree) elements by face option. Now my question is how to deselect the elements by feature angle.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    save your first set of nodes in mark 1, just an example
    *createmark 1 nodes 'by collectorname' theCollectorYouWant
    Now select the nodes you want to remove from set in mark 1
    *createmark 2 nodes 'by cone'
    CONE help:
    'by cone' x y z i j k rb rt h location contained all tol
    Place entities on mark_id if they are inside/outside/on the boundary of the cone.
    x – base center x coordinate
    y – base center y coordinate
    z – base center z coordinate
    i – x-normal, x-coordinate of a point on the cylinder axis
    j – y-normal, y-coordinate of a point on the cylinder axis
    k – z-normal, z-coordinate of a point on the cylinder axis
    rb – radius at the cone base
    rt – radius at the cone top
    h – height.  A negative value indicates the direction is opposite to the normal vector.
    location – The location of the entities to find, relative to the shape.  Valid values are inside, outside, boundary and acrossboundary.
    contained – A flag that indicates whether the entire entity should meet the location criteria (1) or just any part of the entity (0) to be selected.
    all – A flag that indicates whether all entities (1) or only displayed entities (0) are considered for selection.
    tol – The tolerance to use.  In most cases, this should be set to 0.
    This is currently supported for nodes, elements, connectors, components (FE and connectors only), loads, equations, loadcols, systems, systcols, vectors, vectorcols, blocks, groups, sets and contactsurfs.
    set cone parameters that match your angle parameters
    and then, another code line:
    *markdifference nodes 1 nodes 2
    Now you have in mark 1 your nodes but these nodes you wanted to deselect
    regards, drwill
  • tinh
    tinh Altair Community Member
    Hello all,
    example, you already selected some nodes by
    *createmark nodes 1 ... ... ...
    now you want to remove some nodes by feature angle, you can do:
     *createmarkpanel nodes 2 'Select nodes on faces to remove:' *appendmark nodes 2 'by face' *markdifference nodes 1 nodes 2 *clearmark nodes 2
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Tinh,
    Please can you help me how to debug the script using hypermath interface with hypermesh in debugging mode
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hello tinh,
    Can you help me how to ignore the errors by using catch
  • tinh
    Hello tinh,
    Hello
    Please refer to tcl command 'catch' for its usage
    https://www.tcl.tk/man/tcl/TclCmd/contents.htm
    It is better if you post your script here so we can debug it for you
Welcome!
Welcome!
