Can we create our own tests for calibrating the properties in EDEM?
I was trying to model soil bed for simulating the excavation process. All the tests that have been mentioned or available in the resources are not suitable for capturing the soil bed characteristics closely. So, I was wondering where can I find the various kinds of tests that can be performed for calibrating the properties in various applications and if we can create our own tests for calibrating the properties.
1 - 1 of
11
You can build your own specific test, for sure.
But i would first take a look into the installation folder, under examples.
There are several models for the most common calibration tests.
Hope this helps you.
