Weird results for RFORCE
Hi,
I'm applying RFORCE to a propeller but the deformation looks odd.
I have define a point in the center and se X as the rotation vector, set 730 in A (which I believe correspond with 730 rev/s using my units, I know it's extreme but its just a value for testing), and I have created a set with all the elements of the propeller. The root of the blade is not coo-linear with the center of mass of blade in radial direction so I expect some displacement in X direction but not this much.
Can someone tell me what is wrong?
1 - 4 of
41
Hi
It seems that it was locked due to edition.
Please try again the link
https://community.altair.com/community?id=community_blog&sys_id=6b4b361f1b5e6014c4dfdbd9dc4bcba7
Regards
Hi
There is an example in the article:
I hope it helps
Regards
