Running Hypermesh in batch mode with command file
Hi,
I'm trying to automate a fairly basic task which is to be done repeatedly. I've prepared a command file (.cmf) for this. I want to run Hypermesh in batch mode. I found that the way to run hmbatch with tcl file is:
C:\..\hmbatch.exe -tcl myfile.tcl
Can somebody please tell me how to do that for .cmf file?
Will it just be replacing -cmf instead of -tcl?
1 - 1 of
11
I forgot to add that running C:/.../hmbatch.exe -c Myfile.cmf , produces the following error:
-c <commandfile> or -tcl <file> must be used with the hmbatch option.
Isn't that what I'm doing? I tried running as adminstrator also, but it didn't help.
The command file works perfectly as intended when run from within the GUI.
