🎉Community Raffle - Win $25
Join and Win
Export multiple reports from one table
User: "Vanessa_21460"
Altair Community Member
Updated by Vanessa_21460
Hello
Does anyone have experience with exporting multiple reports easily based on a key value.
For example I have one file with 100 lines for 5 different states my key would be "CA', "TX", "CO", "NV", and "NM"​. Is there anyway to export each states file separately? Right now the only way I know how to do this is filter, then export, filter and export over and over. Or create 5 table each with a different export.
Vanessa Tanner
1 - 4 of 41
    User: "Al_22614"
    Updated by Al_22614
    Hello Vanessa:
    Under Monarch Help, please search for and read the section re: Exporting Summary Data Based on Key Value Changes.  This will provide clear instruction on creating separate Excel workbooks or separate worksheets within a workbook, Based on distinct values of the first key.
    HTH
    Al
    Al Rice
    Owner - President- CEO
    Trends In Data, LLC
    West Bloomfield MI
    (248) 761-5238
    Original Message:
    Sent: 09-11-2019 05:03 PM
    Subject: Export multiple reports from one table
    Hello
    For example I have one file with 100 lines for 5 different states my key would be "CA', "TX", "CO", "NV", and "NM". Is there anyway to export each states file separately? Right now the only way I know how to do this is filter, then export, filter and export over and over. Or create 5 table each with a different export.
    Vanessa Tanner
    User: "Mo Abdolrahim"
    Altair Employee
    Updated by Mo Abdolrahim
    Hi Vanessa,
    Based on your description I believe you are using Data Prep studio.  As you already figured it out,  for each state you will need to create a separate table (e.g tbl_CA, tbl_TX, etc) , and then create 5 exports for each table.
    If you use Monarch classic, you can create 5 filters (one filter for each state), then use export and export tables, then select all filters.  Configured the output to be created for each filter (a separate file for each filter) or one Excel file, and multiple worksheet tab for each filter.
    Noticed in the following screenshot the Export table is selected, and All Filter is selected.  If you select By Files option then a separate file will be created.  The file names will be based on the filter name (e.g. ca.xlsx, tx.xlsx).  If you select By Tables , then multiple worksheets will be created in one Excel file.  The worksheet name will be based on the filter name.
    Per Al's suggestion, you can also create a Summary in Monarch classic, and use exporting summary data based on key value changes.  When you build a summary, the first column must be the state field column.
    Currently the above functionalities are only available in Monarch Classic.
    Regards
    Mo Abdolrahim
    Senior Implementation & Integration Engineer
    Datawatch Corporation
    MA
    (978) 935-3840
    Original Message:
    Hello
    Vanessa Tanner
    OP
    Hi Vanessa,
    Regards
    Mo Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Hello
    Vanessa Tanner
    Hello Mo,
    Thank you for the guidance above I went ahead and used classic to create my multiple exports easily and the team is thrilled because this saves so much time.
    In DPS you can export a worksheet with one tab as your table and another tab as your summary. Since DPS does not have the ability to export based on filter my question is does classic have the ability to export tables and summaries based on the filter value into the same report?
    Vanessa Tanner
    Manager Optimization Services
    Gap Inc Store Labs
    San Francisco NM
    (505) 462-0455
    Original Message:
    Sent: 09-12-2019 05:23 AM
    Hi Vanessa,
    Regards
    Mo Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Hello
    Vanessa Tanner
    Altair Employee
    Hello Mo,
    Vanessa Tanner
    Gap Inc Store Labs
    San Francisco NM
    (505) 462-0455
    Original Message:
    Hi Vanessa,
    Regards
    Mo Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Hello
    Vanessa Tanner
    Hi Venessa,
    The Monarch Classic does not have the ability to export table and summary for all filters into the same report.
    This capability is available in the Monarch Server Automator.
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Sent: 09-30-2019 10:44 AM
    Hello Mo,
    Vanessa Tanner
    Gap Inc Store Labs
    San Francisco NM
    (505) 462-0455
    Original Message:
    Hi Vanessa,
    Regards
    Mo Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Hello
    Vanessa Tanner
