why CID for CBUSH is turned on to Zero
VIGNESH_V_25
VIGNESH_V_25 Altair Community Member
edited March 2022 in Community Q&A
why CID for CBUSH elements turned on to Zero ?
What is the purpose of this CBUSH element adding in Connections ? ( Please Anyone explain me in terms of technical way and the analysis reason behind it ).
Answers
  • PaulAltair
    PaulAltair
    Altair Employee
    edited March 2022
    CID on a CBUSH element defines the reference system for the element, the referenced PBUSH property has stiffness inputs for 6 DOF, so the element needs to know which way is X,Y,Z, if CID is set = 0 it  just means the CBUSH is using the global coordinate system (X,Y,Z are aligned with global X,Y,Z)
  • VIGNESH_V_25
    edited March 2022
    Thank you sir, Really helpful.
Welcome!
Welcome!
