Optistruct composite analysis (failed output results)
Hi,
I'm have to run a composite optimization with Optistruct and so I followed all the tutorials set-up steps, but at the point of running the static analysis the results that I obtain doesn't make any sense (displacement 411 cm...). I imagine it could be a problem of units but I've checked them and I cannot find out where the problem is. I've had defined the 'DTI_UNITS' card with the units Kg,N,mm,s and I've also set all the values introduce into these units. Even the value of the G force applied is -9810 (mm/s2). So I really don't know where the problem comes from.
I send attached the output file results. If you need any other information to help me solving this, tell me please. Thank you very much in advance.
Hello,
I've changed just the units of the G force from 9810 (mm/s2) to 9.81 (m/s2) and maintain in Kg,N,mm,s all the other values (material properties, etc). Now the results are good. Is it ok that the G force is in m/s2 while the other values are in mm?
Thank you for your answer!
Hello,
You can calculate for your self /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> using F= Ma.
Newton= Kg* m/s^2. So what you are using makes sense.
Hello,
For a static analysis, i dont think dti unit card doesnt really has an effect.
Maintain unit consistency in your model and try again
