Fabric law 58 defined by stress-strain curve
Hi,
the fabric law 58 is defined by stress-strain curves and parameters found in the referenece guide, which are scaled 1000x to be consistent with the tonne, mm, s unit system. However, all elements get deleted at the start of simulation with the message:
-- DELETE 3N SHELL ELEMENT : 10 AT TIME : 0.9001E-05
Adding DT/NODA/CST does not resolve the issue- the elements still get deleted at the start, even though there is no such message in the out file.
This is strange since the imposed displacement (+ 0.1 strain) should be within stress-strain curve.
Please find the model attached bellow.
HI,
From RADIOSS help:
#RADIOSS STARTER #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /UNIT/1 unit for mat kg mm ms #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| #- 2. MATERIALS: #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /MAT/<span>LAW</span><span>58</span>/1/1 Altair test fabric <span>LAW</span><span>58</span> # RHO_I 8e-07 # E1 B1 E2 B2 FLEX 0.38 0 0.38 0 1 # G0 GT AlphaT Gsh sensor_ID 0.0035 0.0055 7.175 0 1 # Df Ds GFROT ZERO_STRESS 0.00 0.00 0 1 # N1 N2 S1 S2 FLEX1 FLEX2 1 1 0 0 0 0 # fct_ID1 Fscale1 500 1 # fct_ID2 Fscale2 501 1.07 # fct_ID3 Fscale3 502 1 #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /FUNCT/500 stress-strain curve dir 1 # true strain true stress 0.0000000000e+000 0 9.9503308532e-003 2.9636979188e-003 1.9802627296e-002 5.3682944250e-003 2.95<span>58</span>802242e-002 7.1312474875e-003 3.9220713153e-002 8.7543744167e-003 4.8790164169e-002 1.0626227281e-002 5.8268908124e-002 1.2828957400e-002 6.76<span>58</span>648474e-002 1.5214981140e-002 7.6961041136e-002 1.7923677525e-002 8.6177696241e-002 2.09310474<span>58</span>e-002 9.5310179804e-002 2.4244941875e-002 1.0436001532e-001 2.8050134750e-002 1.1332868531e-001 3.2157106333e-002 1.2221763272e-001 3.6791281562e-002 1.3102826241e-001 4.1811352500e-002 1.3976194238e-001 4.718<span>58</span>17708e-002 1.4842000512e-001 5.3009665500e-002 /FUNCT/501 stress-strain curve dir 2 # true strain true stress 0.0000000000e+000 0 9.9503308532e-003 3.7850414917e-003 1.9802627296e-002 6.6041801875e-003 2.95<span>58</span>802242e-002 8.9026150938e-003 3.9220713153e-002 1.1200598067e-002 4.8790164169e-002 1.3569178437e-002 5.8268908124e-002 1.6244941225e-002 6.76<span>58</span>648474e-002 1.9356706823e-002 7.6961041136e-002 2.2930409250e-002 8.6177696241e-002 2.7109342313e-002 9.5310179804e-002 3.1773431250e-002 1.0436001532e-001 3.6903321313e-002 1.1332868531e-001 4.2590270333e-002 1.2221763272e-001 4.8734555250e-002 1.3102826241e-001 5.5311888000e-002 1.3976194238e-001 6.2350489167e-002 1.4842000512e-001 6.9690045000e-002 #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /FUNCT/502 stress-strain curve dir 12 # angle true stress -16.170000000e-000 -1.5741500000e-003 -7.1750000000e-000 -4.3750000000e-004 0.0000000000e+000 0.0000000000e+000 7.1750000000e-000 4.3750000000e-004 16.170000000e-000 1.5741500000e-003 #ENDDATA /END #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|
Hi,
in the attached file the material model is duplicated verbatim (imported solver deck copied form Radioss help), but the elements still get deleted from the start. Therefore I suspect this material model is not functional with stress-strain curve input. Please verifiy at your end.
Hi @Ivan
Can you add DT/NODA/CST to the engine with Scale of 0.6 and Tmin of 1e-6 and check if that helps?
