🎉Community Raffle - Win $25
Join and Win
Weld vs Rigid Elements
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Can anyone specify what the difference between the weld and rigid element configs are in the Hypermesh V11 spotweld panel?
Thanks!
1 - 2 of 21
    Altair Employee
    OP
    'weld' and 'rigids' are simple names for 'generic' elements in HyperMesh. It depends on the solver you work with, what FE elements they will represent. You can check this in the 'elem types' panel. In the case of RADIOSS, a 'weld' element would be a RBAR and a 'rigid' element a RBE2
    Regards,
    Stefan
    Altair Employee
    OP
    Thanks Stefan!
    So what I get from this that using RADIOSS, there is really no difference between the RBAR (Rigid Bar) and the 'rigid' element other that you can set the 6 DOF with the RBAR if you look at the solver deck.
    Adrian
