Can anyone specify what the difference between the weld and rigid element configs are in the Hypermesh V11 spotweld panel?
Thanks!
'weld' and 'rigids' are simple names for 'generic' elements in HyperMesh. It depends on the solver you work with, what FE elements they will represent. You can check this in the 'elem types' panel. In the case of RADIOSS, a 'weld' element would be a RBAR and a 'rigid' element a RBE2
Stefan
Thanks Stefan!
So what I get from this that using RADIOSS, there is really no difference between the RBAR (Rigid Bar) and the 'rigid' element other that you can set the 6 DOF with the RBAR if you look at the solver deck.
Adrian
