Altair RISE
Nominate Yourself Now!
My custom menu is not reloading when i change the profile?
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
My custom menu from hmcustom.tclis not reloading when i change the profile?
Which code should be added and where, how to add?
Also, tell me some materials or links where i can learn to customize hypermesh dropdown menu.
1 - 18 of 181
    User: "tinh"
    Updated by tinh
    Hi
    you have to register a callback:
    hm_framework registerproc ::p_CallbackAfterUserProfileChanged after_userprofile
    then in body of the callback proc, you reload dropdown menus
    OP
    Hi Tinh, I am new to framework. Please tell me where I have to put my code
    User: "tinh"
    Updated by tinh
    Hi Jouher,
    example in file c:/users/jouher/hmcustom.tcl
    you put these codes:
    proc ::p_CallbackAfterUserProfileChanged args {
         p_CreateDropdown Jouher
         #and other codes you want to run after changing profile
    proc ::p_CreateDropdown Menu {
         set main  [. cget -menu]
         catch {menu $main.mnu$Menu -tearoff 0}
         $main add cascade -label $Menu -menu $main.mnu$Menu
         return $main.mnu$Menu
    ::p_CreateDropdown Jouher
    OP
    Hi Tinh,
    Below is my code,
     set mypath 'C:/Users/MYNAME/myscripts';   set top_menu [hm_framework getpulldowns]  catch {$top_menu delete [.hmMainMenuBar index 'MyMenu']}  catch {destroy $top_menu.custom}   menu $top_menu.custom -tearoff 0  $top_menu insert 20 cascade -label 'MyMenu' -menu $top_menu.custom   set cat1 $top_menu.custom  $cat1 add cascade -label 'Category 1' -underline 0 -menu [menu $cat1.mnu1 -title 'Cat-1']  $cat1.mnu1 add command -label 'Script 1' -command 'source {$mypath/script1.tcl}' -underline 0  $cat1.mnu1 add command -label 'Script 2' -command 'source {$mypath/script2.tcl}' -underline 0   $top_menu.custom add separator   set cat2 $top_menu.custom  $cat2 add cascade -label 'Category 2' -underline 0 -menu [menu $cat2.mnu2 -title 'Cat-2']  $cat2.mnu2 add command -label 'Script 21' -command 'source {$mypath/script21.tcl}' -underline 0  $cat2.mnu2 add command -label 'Script 22' -command 'source {$mypath/script22.tcl}' -underline 0
    how should i add this in your command?
    User: "tinh"
    Updated by tinh
    Hi Jouher
    save your codes in a file example C:\Users\YourName\yourmenu.tcl
    and modify below proc in the hmcustom.tcl
           source 'C:\Users\YourName\yourmenu.tcl'
    OP
    Hi Tinh, its throwing error. I want my code at start and after changing profile too.
    User: "tinh"
    Updated by tinh
    Sorry Jouher, it is due to \
    It (C:/Users/YourName/hmcustom.tcl file) should be
           source 'C:/Users/YourName/yourmenu.tcl'
    OP
    i have done that.
    but still it show error after changing the profile as shown in figure.
    window name 'summary' already exists in parent
        while executing
    'frame $f'
        (file 'C:/Users/Jouher/Desktop/Jouher_custom/hmcustom.tcl' line 13)
    There is a frame already in my file.
    See the above replies to see my code in file.
    see my code also.
           source 'C:/Users/Jouher/Desktop/Jouher_custom/hmcustom.tcl'
    User: "tinh"
    Updated by tinh
    Hi Jouher,
    just add a destructor before command 'frame $f' , like this:
    destroy $f
    frame $f
    OP
    Thanks Tinh, its working.
    User: "Jack LC_22402"
    Updated by Jack LC_22402
    Hello tinh,
    I've a problem with custom menu in the HM release 2019. Now the custom menu is not reloading when I import a model, while your code works great with user profile change. I tried to find something in the manual "hm_framework registerproc" but without success.
    May you suggest me a code to reload custom menu when I import new models?
    Many thanks
    Jack LC
    User: "tinh"
    Updated by tinh
    Hi Jack,
    as I know, when we import a model, HM will not reset its menus.
    So your case looks strange. Could you take some photos?
    We can register a callback to reload menus after importing new models. But i suggest you first to close HM and delete files .../Documents/hmsettings.tcl; .../Documents/hmmenu.set; .../Documents/command.tcl
    then try again
    Hi tinh,
    thanks tinh for your reply and your suggestions.
    To make a test, I created a simplified version of the custom menu. Then I did the following:
    1) Delete files hmmenu.set and command.tcl (hmsettings.tcl not present in my starting folder)
    2) Open HM, the menu is present
    3) Import an abaqus model; as you can see in the picture below, the menu disappeared
    The files I used are the following (I'm not an expert, I copied them from your posts):
    1) hmcustom.tcl
    proc ::p_CallbackAfterUserProfileChanged args {         source "C:/Disk_D/Dati/settings/HW/TestMenu.tcl"  }  hm_framework registerproc ::p_CallbackAfterUserProfileChanged after_userprofile  ::p_CallbackAfterUserProfileChanged  hm_framework registerproc ::p_CallbackAfterUserProfileChanged after_menudraw  ::p_CallbackAfterUserProfileChanged
    2) TestMenu.tcl
    # # Creation Menu in HM # set TopMenu [hm_framework getpulldowns]  catch {$TopMenu delete [.hmMainMenuBar index "TEST"]} catch {destroy $TopMenu.test}  menu $TopMenu.test -tearoff 0 $TopMenu insert 20 cascade -label "TEST" -menu $TopMenu.test   $TopMenu.test add separator
    Since my case is strange, maybe it is related to my HM version (2019.1)
    Best regards,
    Jack LC
    User: "tinh"
    Updated by tinh
    Hi I will check abaqus profile, it could register a proc to reset menus. It is not registered to profile-change event, so we will bind our callback to something else, there are several ways to bind a callback. Let's check it later because i don't have hypermesh at home :D
    Hi,
    you are right, it seems related to the abaqus profile. I tried with the Optistruct profile and it works fine, no reset of the custom menu.
    Thanks,
    Jack LC
    User: "tinh"
    Updated by tinh
    Hi Jack,
    i found a registered proc is hooked to import command, so it (calls to) reset menus.
    in your hmcustom.tcl :
    proc ::p_AddUserMenus args { 	source "C:/Disk_D/Dati/settings/HW/TestMenu.tcl" } proc ::p_CallbackAfterUserProfileChanged args { 	#check if Abaqus profile is loaded: 	if {[string equal -nocase $args Abaqus]} { 		trace remove execution ::UserProfiles::Abaqus::UpdatePulldowns leave ::p_AddUserMenus 		trace add execution ::UserProfiles::Abaqus::UpdatePulldowns leave ::p_AddUserMenus 	} 	::p_AddUserMenus }  hm_framework registerproc ::p_CallbackAfterUserProfileChanged after_userprofile  ::p_CallbackAfterUserProfileChanged
    do not register proc for event "after_menudraw", it may hang your hypermesh!
    Hi tinh,
    wow, it works perfectly! Honestly, I don't understand how the lines "trace remove ..." and "trace add ..." can solve the issue, but it works.
    Many thanks for your valuable help!
    Jack LC
    User: "Ajay Prabhakaran"
    Updated by Ajay Prabhakaran
    Hi tinh,
    Do you have any alternative way for registering a proc , as the method (
    ) wont work in Hyperworks X version with hm_framework. Do you have an alternative that will work for Hyperworks -X version?
