remesh
User: "tehran"
Altair Community Member
Updated by tehran
how can I use remesh in a 3d model?
 when I try to use remesh around rotating part I faced to this error
Remeshing of Mecha. Sets impossible on the current time step
Remeshing of Mecha. Sets impossible on the previous time step
regards
1 - 4 of 41
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    You get this error message when you try to solve the project? In this case can check your physics you sing the command “check physics’ from the menu physics, if you get an error message, you need to see your physics (for example assign of mechanical parts). Once you have corrected all the error message, try to solve the project. If the problem persist, send us your Flux project (zip format).
    Best regards.
    User: "tehran"
    OP
    Updated by tehran
    thank you I will send you my project
    User: "tehran"
    OP
    Updated by tehran
    Hi,
    Best regards.
     in attach in send my project
    best regards
    User: "tehran"
    OP
    Updated by tehran
    Hi,
    Best regards.
    please test my file
    best regrads
