Hi,
You get this error message when you try to solve the project? In this case can check your physics you sing the command “check physics’ from the menu physics, if you get an error message, you need to see your physics (for example assign of mechanical parts). Once you have corrected all the error message, try to solve the project. If the problem persist, send us your Flux project (zip format).
Best regards.
in attach in send my project
best regards
Hi,
Best regards.
please test my file
best regrads
Hi,
Best regards.
