Query in using Palettes
Hello, I am using Altair Activate to simulate a reduced order task. My model is a linear model and after training the model, I have two input variables (two columns) based on which the result is predicted (ideally the output will be one column of data). I am using the FromCSV palette as input and the ToCSV palette as output. But these two are time-dependent whereas my model is a linear model. The output I am getting is a single value instead of a column of data. Please help me with the input and output palette options where I think I am making a mistake. I have attached an image for your reference. Thanks in advance.
Hi João Marabisa,
Thanks for your quick reply and help. I tried the workflow as suggested where the inputs work fine but the output still prints out only one data where I'm expecting a column of data. Please advise on the same. I have attached an image for your reference.
I have also attached an instance evaluation graph from romAI, where the pressure_coefficient (output) has multiple data after training as expected. I'm looking to recreate the same with different inputs.
The error I get is: Error: Incompatible port sizes in function setio at line number 175 in file MatrixConcatenation.oml
I really appreciate your time and help.
Thanks.
Abhijith
Hi João Marabisa,
Thanks.
Abhijith
Hi Abhijith,
I think your "Display" block is working as expected. You have a single variable (Pressure_Coefficient2) that is varying, so it is expected to see just one value on Display block.
Please try to use the "ToCSV" block, you should see a complete column of all the values that were calculated through "n-Xaxis":
Hope it helps you,
João.
Hi Abhijith,
In that case, you can use both 'csvread' and 'csvwrite' functions on OML Initialization and Finalization sections, respectively:
I attached the model that should work for your purposes. Please, don't forget to change to your own directory path.
Hope it helps you,
João.
