🎉Community Raffle - Win $25
Join and Win
How to delete floating elements
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
im doing a study with different optimizations. In this case i compare the results without remeshing. For analysis i need to delete the elements which are not connected with the others.
In this case i have a lot of this elements. Is there a possibility for automatisation? A function in hypermesh to delete the floating elements...
Thank you very much
Andreas
1 - 4 of 41
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Try: F2 => elems => by attached => reverse => delete entity
    Altair Employee
    OP
    Thank you Q.Nguyen-Dai,
    it helps to remove the elements which were not attached. But i still have a lot of elements which have a negativ affect to the analysis.
    Does anybody know how to delete these elements?
    Thanks
    Or wirte a TCL script to select 'bad' elements according to your criterion and then delete them.
    Altair Employee
    OP
    Can you tell me how to to that. I have no experiance with TCL
    Or  do somebody know another posibility for this?
    Thank you
