🎉Community Raffle - Win $25
Join and Win
Difference gain in FEKO and measure
Hello,
I simulate a MIFA antenna at 868 MHz as below.
The problem is that I measure a maximum gain of around 0 dB with FEKO and when I measure the gain with a VNA, I obtain a gain around -8 dB. The measurement has been made in the same conditions.
Does this difference can be explain with the loop on the top of the antenna which cancel currents and electric field ?
Thank you all
1 - 7 of 71
