MBD
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
What is this error? How to resolve this?
Welcome!
Answers
  • Beta
    Beta New Altair Community Member
    edited June 2019
    This error usually appear when you reopen an Motion View file which including Altair Diriver or some parts in Wizard library. It is due to wrong selection in attachment for systes or assembly.
    When I get this problem, I just ignore it and try run a test run. Usually, the problem will solve itself
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2019
    When I  get this problem ,I dont get any 'Add Events' option on right click on Model.So How to add Analysis like constant radius ,single lane change?
    Does Student version of Hyperworks has license for Altair driver?
  • Praful
    Praful
    Altair Employee
    edited June 2019
    Hi Adit - What this error says is that the model was created with one set of wizard and the current wizard is a different one. Usually, the assembly and task wizards work together. The tasks in the task wizard are or can be configured based on what was selected in the model wizard. If there is a mismatch, the task wizard won't appear.
    Regarding the events not appearing, could you go to File > Load > Preference File , select 'MBD Vehicle Dynamics Tools' and click Load. ? Did that work ?
    regards
    praful
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2019
    I have loaded MBD Vehicle Dynamics Tools but still no 'Ad events ' option is there.
    In the attached image vehicle tools option is there in menu which means MBD vehicle dynamics tools is loaded but no 'Add events ' is there.
  • Chris Coker_21312
    Chris Coker_21312 New Altair Community Member
    edited June 2019
    Did you create the vehicle model from the existing wizard library, or did you create this from scratch?  One thing I have noticed in your screenshots, is that the icon for 'Altair Driver' does not look like a driver's helmet.  Also, the modeling entities for the 'Altair Driver' do not get exposed to the user when everything is set up correctly.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2019
    I have created the model using user/custom library with its wizard file.
  • Chris Coker_21312
    edited June 2019
    There is likely some incompatibility between your user/custom wizard, and the way the default library model/events work.  I would suggest that you study how the default library and event topology is configured, and use that as a pattern for designing your own custom wizard.  There is specific code (and logic) for how the events communicate with the vehicle models.  If you do not match this logic flow in your custom wizard, the events will not know now to connect to your custom models.
Welcome!
Welcome!
