Can edemAPI achieve geometry that only comes into contact with one type of particle, but not with other particles?
User: "bigshow"
Altair Community Member
Updated by bigshow
1 - 2 of 21
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Xixihaha,
    You can ignore the contacts from specified particle types.  All particle - geometry contacts are detected however you do get given the particle name.  You can write a model to apply zero force to those particle types.
    In the recent versions of the API the forces are chained, so if you have a model at the end of the chain which overwrites and sets the force to =0 then this will overwrite the forces calculatedfrom other models in the chain and just return 0.
    There is a similar example here EDEM API - Contact Model Example: Removing Particles
    Regards
    Stephen
    User: "bigshow"
    OP
    Updated by bigshow
    Hi Xixihaha,
    Regards
    Stephen
    thank you very much
