Altair RISE
Nominate Yourself Now!
Splitting CBEAM elements into individual properties
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have a structure that is composed of many CBEAM elements, all of these CBEAM elements are under one property and one material. I need each of the individual CBEAM elements to have its own property and material. Is there a way to automate this. I have ~9000 beams.
I could lower the number of beams to something manageable so I could organize them individually but this is not ideal.
The end goal is to be able to alter the material properties of individual CBEAM's, E1 for example, simulating progressive damage with progressive lattice failure.
Can anyone help?
I have attached my .fem and hm for your visualisation.
Kind Regards,
Laurence
1 - 9 of 91
    User: "Merula_20758"
    Altair Community Member
    Updated by Merula_20758
    You can solve this with a .tcl script easily. Are you familiar with scripting ?
    Best regards
    Merula
     *createmark elements 1 'by config' 'bar' set beamIds [hm_getmark elements 1]  foreach beamID $beamIds { # Create New Component  *createentity comps name=Component_$beamID # create material *createentity mats cardimage=MAT1 name=material_$beamID set materialID [hm_entityinfo id material 'material_$beamID'] *setvalue mats id=$materialID STATUS=1 1=210000 *setvalue mats id=$materialID STATUS=1 3=0.3 *setvalue mats id=$materialID STATUS=1 4=7.85e-009 *setvalue mats id=$materialID STATUS=1 2=80769.2 # Create New Property *createentity props cardimage=PBEAM name=property_$beamID set propertyID [hm_entityinfo id property 'property_$beamID'] *setvalue props id=$propertyID cardimage='PBEAM' *setvalue props id=$propertyID materialid={mats $materialID}  # Assign it to Component ## Assign the property and Material *setvalue comps id=[hm_entityinfo id component 'Component_$beamID'] propertyid={props $propertyID} ## Assign BeamSection To Property *setvalue props id=$propertyID STATUS=2 3186={beamsects 1} *createmark properties 1 $propertyID *syncpropertybeamsectionvalues 1 *mergehistorystate '' '' *setvalue props id=$propertyID STATUS=2 500=1 *setvalue props id=$propertyID STATUS=0 36=0 *setvalue props id=$propertyID STATUS=0 37=0 *setvalue props id=$propertyID STATUS=0 38=0 *setvalue props id=$propertyID STATUS=0 39=0  #Move Element *createmark elements 1 $beamID *movemark elements 1 'Component_$beamID'  }
    It for sure is not ideal and it will take a while but I am curious what the experts think about it :-D
    Best regards
    Merula
    Altair Employee
    OP
    Hi Merula,
    Thank you for the script. I had a go on my model and I get a response that says 'beamIds' can't be read, no variable exists. Do you have any idea why?
    Thanks,
    Laurence
    User: "tinh"
    Updated by tinh
    I wonder how you alter E1 of 9000 items?
    Hi Merula,
    Thanks,
    Laurence
    Did you execute the first two lines?
    User Profile Optistruct?
    maybe just copy it into the tcl command console (at the bottom of the window)
    Hope this helps
    Merula
    Good question... I suggest he wants to do it with a location... so all beams with a distance lower than x ...
    Altair Employee
    OP
    Hope this helps
    Merula
    Hi Merula & Tinh
    I now get a message saying '*syncpropertybeamsectionvalues' is an invalid command name.
    The basic idea of this is to simulate lattice failure by changing the stiffness, i.e. E1. I've written a basic script that alters the MAT1 material data card for a single  CBEAM property, this uses the allowable range that E1 can be.
    I can lower the number of bars if necessary, if ~9000 is too computationally challenging.
    Thanks,
    Laurence
    Altair Employee
    OP
    Danke Merula,
    The script works perfectly. It is a good base for what I intend to do.
    Kind Regards,
    Laurence
    Perfect. Good luck!
