Zone based realization
Hello,
I am doing the Aircraft Door Surround Composite Skin Model. I did everything but when I try to do the zone based realization, it is done correctly, but when I try to run I get the error "
Messages for the job:
*** ERROR # 622 ***
PLY 141 does not contain any valid plate elements referencing a
PCOMPP card.
What can I do to fix this? Thanks.
1 - 8 of
81
No; I didn't delete anything. I did exactly as in the video. Should I delete plies? I have v2021.2.
If you are not using the plies and they are in you model as unused/empty, then yes, like any other Optistruct entity they will error. I am fairly certain in one of the videos it is mentioned it is good habit to delete ply data when realizing if you are using this as your final export model.
Hello Vuk,
Have you looked into this Youtube Training Series yet?
