🎉Community Raffle - Win $25
Join and Win
Crushable foam material in optistruct
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am trying to model expanded polypropylene material and i am trying to figure out what material Id and property type we must use in optistruct.
Thanks
1 - 15 of 151
    Altair Employee
    OP
    Hi Adithya,
    What is the analysis about?
    You can use MATX33, MATX70
    Or use RADIOSS with LAW33, LAW 70
    Altair Employee
    OP
    Hi, Thank you for your response.
    It is a non linear quasi static analysis on the seat. I am using EPP material for the foam.
    Altair Employee
    OP
    Hi @Adithya
    I suggest you use RADIOSS for such a problem.
    Altair Employee
    OP
    I need to further optimize the design, thats why i am modelling it with optistruct, right now, I tried converting from optistruct to radioss but i am missing 1d elements which were placed on the components. I am using the latest version of 2017.2
    Altair Employee
    OP
    Hi @Adithya
    What type of Optimization are you planning to do?
    RADIOSS does supports optimization starting from 2017. Please refer to this example problem of thickness optimization on a B-pillar
    RD-E: 5100 Optimization in RADIOSS for B-Pillar (Thickness optimization)
    Altair Employee
    OP
    Hi,
    Its a composite material, and i would need to perform and try all the 3steps available in optistruct. Btw my analysis is taking very long time to run, this has been the case ever since i gave tie connection between a solid element and shell element, is there a more less time consuming way to solve this? because before having the solid elements and connections, it took lesser time to compute, will a 1D connection with rigid element solve the issue? Also i am not facing any issues in optistruct with the file, I am using NLGEOM as i have a foam material.
    Altair Employee
    OP
    • I tried with 1d connections as well, it doesnt seem to work. For nlstat the same amount of element and connections, the results are getting computed faster, i think it has to do with something in Nlelast type.
    Altair Employee
    OP
    Hi @Adithya
    Is it possible to share the model file, please?
    Please use the file transfer link in my signature to share the model file
    Altair Employee
    OP
    Hi, I have attached the file in the file transfer link
    Thank you.
    Altair Employee
    OP
    Hi @Adithya
    I didn't receive any file at my end.
    Altair Employee
    OP
    Hmm, that is strange. I have sent you the file again. Please check
    Thank you.
    Altair Employee
    OP
    @Adithya
    I got the files. thank you
    I see that you are running a linear static analysis.
    Altair Employee
    OP
    Hi no, I am running a nonlinear geometric analysis.
    Altair Employee
    OP
    Hi @Adithya
    OK, It is NLGEOM and I am running the file right now.
    One way to increase the speed of the analysis is to use a coarser mesh instead of a finer mesh.
    Altair Employee
    OP
    Hi Prakash
    Oh great, Is it taking too long or did you get any results?
    Thank you.
