🎉Community Raffle - Win $25
Join and Win
Optistruct Error #193
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I ran into this error when I created ASET for optistruct to solve for Superelement. I have no idea what this error means. Can anyone help?
 A fatal error has been detected during input processing:
  *** ERROR # 193 ***
  Possible programming Error :
  Unexpected error condition from subroutine xdnrsf.
    ioerr(1) = -301
    ioerr(2) = 1
    ioerr(3) = 1
1 - 4 of 41
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Could you share us the complete out file and your system & update information?
    Regards
    Rahul R
    Altair Employee
    OP
    I already spoke with one of the Altair support engineers. Apparently, there is a limit of ASET nodes and it's limited by the computer hardware which I am running the analysis on.
    Altair Employee
    OP
    Hi Rahul,
    I had already generated superelement reduction model in .pch format of Big BIW model. When I  run main model with same super element in Altair Compute Manage (PBS), Run is not running, it converted in waiting status. Pl check below warning file. .
     *** WARNING # 2327
     PARAM,AMSES is obsolete and will not be supported in the future.
     Use EIGRA data, or specify AMSES in field 7 of the CMSMETH data.
     **                        OptiStruct 2017.2.1                         **
     **             Advanced Engineering Analysis, Design and              **
     **        Optimization Software from Altair Engineering, Inc.         **
     **               Linux  2.6.18-308.el5  calc01.cluster                **
     **          8 CPU:  Intel(R) Xeon(R) CPU E5-2643 0 @ 3.30GHz          **
     **                    258053 MB RAM,  8189 MB swap                    **
     ** Build tag: 0879591_0433172_Le64RBW8UH14M:133493-1  100000020004205 **
     **  COPYRIGHT (C) 1996-2017                 Altair Engineering, Inc.  **
     ** All Rights Reserved.  Copyright notice does not imply publication. **
     **         Contains trade secrets of Altair Engineering, Inc.         **
     ** Decompilation or disassembly of this software strictly prohibited. **
     WARNING:
     The amount of memory allocated for the run is 4430 MB, which
     is larger than the specified (or the default) RAM= 4000 MB.
     This run will use out of core processing in the solver.
    optistruct:: Solver run finished after 86 minutes.
    export ALTAIR_LICENSE_PATH=6200@gxhpctl:6200@calc01:6200@xgbackfs.cluster; /app/HyperWorks/2017.2/altair/scripts/optistruct -amses yes -checkel no -tmpdir $PBS_JOBDIR D01L_AS_base_BG003_upt3_28Aug_svy_study2_acmdfflmgi3.fem -len 4000 -nproc 2
    Pl help
    Altair Employee
    OP
    Hi Shivray,
    I see that OptiStruct solver run finished from your last message.
    Could you please check?
