How to review Elastic property Value of Spring Element
User: "Alex Nguyen"
Altair Community Member
Updated by Alex Nguyen
Hi everyone, I have just created several spring elements with K=1.05 (Elastic property Value).
I want to review Elastic property Value (K) of these spring element but impossible.
How to review Elastic property Value of Spring Element?
Thanks everyone!
1 - 9 of 91
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Which CARD image do you use for Spring property?
    User: "Alex Nguyen"
    OP
    Dear @Q.Nguyen-Dai
    My CARD Image is PELAS, after I created Spring Element. I want to re-check K factor but still not yet.
    I also use REVIEW option of spring but I only see dofs.
    Review panel on element gives you DoF.
    Review K value, you have already 'Property editor', not on Element panel.
    User: "Alex Nguyen"
    OP
    Where is 'Property Editor' in HyperMesh?
    Please teach me.
    When you click on a Property within 'Model view', you see 'Editor' below:
    <?xml version="1.0" encoding="UTF-8"?>prop.thumb.png.7e1b73c16638995b08d48ac843272bb9.png
    When you define your Spring, you does not give directly K value into element definition, but you link this element to a Property (PELAS in your case)
    User: "Alex Nguyen"
    OP
    Tks @Q.Nguyen-Dai
    Now I want to check K value of  a element. I choose element and I want to know K value of that element.
    Because I have 3 Kx,Ky,Kz for a couple node. So I want to re-check
    Best Regard
    What do you do to create this Spring element?
    I think the way: Mesh -> Create -> 1D Element -> Springs -> ...., right ?
    User: "Alex Nguyen"
    OP
    Dear @Q.Nguyen-Dai
    Yes, I made as your thinking.
    I have just found answer for my question. When I review panel on element gives me DoF, it also give me the PROPERTY of element which I make review.
    It's right as you said, Value was linked element to a Property (PELAS in your case)
    Thanks @Q.Nguyen-Dai very much for your support:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "muhammad ali raza abid"
    Updated by muhammad ali raza abid
    Dear @Alex Nguyen Can you please describe how to create 3 spring elements at one location so as to define Kx, Ky, Kz for one particular location?
    THanks in advance
