Importing geometry from Solidwork
Hi there. I have met a few problems with importing geometry from Solidwork.
As I am using the student version, I have imported solidwork file to CADFEKO in parasolid format.
I am looking for the inductance of the model so I have meshed the model and solved it to obtain the output file.
In the output file, it only shows the capacitance of the model:
Then, I have built a similar model using CADFEKO. But this time it shows the inductance of the model is 2.7uH.
The dimensions, model extent, voltage source, frequency used in both files are the same. I expected the results from both files would be similar.
At least both of them should have inductance shown in the output file.
Why there is such a big difference in the results? Is there anything I have done wrong?
I am sorry I must have uploaded the wrong file. Attached should be the right one.
GeomImport1 is wire and GeomImport2 has edges and faces.
The import contains a wire loop and loop made from a cylinder.
I deleted the wire loop part.
For the disconnected faces, where the meshes don't align, select the two faces adjacent the disjoint, right-click to Copy (duplicate).
Then select the two copied faces and click on Stitch.
Then delete the two original faces from the original part.
Then Union the Stitch with the original part (part where the two faces were deleted).
I added an edge port as seen below and get 2.7 uH.
Some images.
Sorry there is one more question.
I found these warnings in the output file:
WARNING 510: Imaginary part of the impedance is large thus the real part will be inaccurate
WARNING 509: Reactive power large thus real power is inaccurate
Do they have a big impact on the results? Is there anything I can do with them?
You must use double precision - enter the text in the search bar on the top right of cadfeko if you don't know where to enable this.
The mesh will look 'cubical' if there are not enough triangles around the circumference of the tube.
You can also view the mesh in CADFEKO by disabling the Overlay and Model view icons and only enabling the Simulation mesh view icon on the Display options tab.
Connectivity can be viewed by clicking the Connectivity icon.
But I have now met another problem. I am simulating the antenna which was fabricated on a pcb. So the cable is actually flat instead of cylindrical.
I have redrawn the whole antenna and try to simulate it. This time I have stitched all the faces and union them.
The triangle edges was set to 0.001.
However, I did not get the same result. I wonder if you have any idea.
Just looking at your two *.out files (you only attached only one model's cfx) I see 8700 triangles in the 'solidworks' model while the cadfeko model only has wire segments, and then only 155.
The two meshes are way different from each other and therefore the results would be too.
