I have 2 parts forming t section whose midsurface is extracted which creates gap between the parts,to overcome the same i extended the one surface and projected on other , after meshing nodes gets merged is their any need to define contact between the parts as i want to fix these parts ?
If nodes are merged at the junction for a single part then no need to define contact for those regions.
