How can I combine edges/lines in Hypermesh?
Hello,
after creating a geometry (solid) out of a FE-Mesh, there are many lines/edges in the geometry. For meshing I can use the edge edit -> toggle funtion. But when I export the model as a step-file to Abaqus the lines are still visible. Is it possible to delete or combine these lines completely?
thanks in advance
Justus
