🎉Community Raffle - Win $25
Join and Win
How can i specify the number of adaptive solutions ?
I am doing static analysis. when I apply adapt for stress I got for example 17MPa, when i apply custom and solution number 7 and refinement level is high, I got 60MPa. which type of result I trust?
1 - 1 of 11
    in SimSolid you can control the solution refinement level, in a trade-off of speed and accuracy.
    I'd suggest you to perform a converge study, and gradually increasing the solution level, until you get a stable solution.
    Also in order to get a better solution, you can create refinement groups, allowing SimSolid to refine more a few parts of your model, where you're focusing.
