How to export simulation data containing map information using WinProp?
I have set up two transmitters in a map using WinProp and obtained simulated spectrum power plots for each, as shown in the figure.
However, what I want to obtain is a simulation plot when both transmitters are operating simultaneously, meaning the two simulation plots should be overlaid. How can I achieve this?
Additionally, I also hope to export simulation results containing map information in a specific data format rather than images. For example, the simulated data from the top-left corner of the map should be placed in the top-left corner of a table, and so on, with no data filled in areas where buildings are located. I've looked into the XML format of exported data, but I'm not sure which part of the map the numerical values correspond to in the simulation results.
If you can help me solve these problems, I would be extremely grateful. I apologize for taking up your time, and I look forward to your response.
