Optistruct hang in PRPDDM randomly when using DDM on 2 hosts
Michael Faulwasser
Michael Faulwasser Altair Community Member
edited February 2024 in Community Q&A
If I run a model on 2 hosts in our cluster it randomly hangs in phase PRPDDM. I can only control on which subcluster and with which hardwareproperties the jobs run. If I run the same job just on 1 host it runs. I use always the same model in order to get optistruct on two hosts in ddm mode running.
some generic information about the model
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :   9503019
  Total # of Elements Excluding Contact:   7370969
  Total # of S2S Contact Elements (3D) :    126903 (no internally created CGAPG)
  Total # of Rigid Elements            :    142445
  Total # of Rigid Element Constraints :   1019739
  Total # of Local Coordinate Systems  :       261
  Total # of Degrees of Freedom        :  34714278
  (Structural)
  Total # of Non-zero Stiffness Terms
  for this Local Domain                : 642160205
  Element Type Information
   CBAR     Elements   :      705
   CELAS2/4 Elements   :       10
   CHEXA    Elements   :   198721
   CTETRA   Elements   :  5185338
   CPENTA   Elements   :     9974
   CONM2    Elements   :       30
   CQUAD4   Elements   :  1889050
   CTRIA3   Elements   :    86834
   CBUSH    Elements   :      307
Thanks for all hints
Answers
  • Xiaolei
    Xiaolei
    Altair Employee
    Hi Michael,
    It's hart to tell. Would you mind creating a support ticket, or sending this to hwsupport@altair.com, then we can take it from there?
    Thanks.
    Xiaolei
Welcome!
Welcome!
