Altair RISE
Nominate Yourself Now!
Is there any example about midsurface extract and repair script for complex structure?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
For complex thin structure, we often cannot get a complete midsurface. That is to say, the surface  is  discontinuity or intersection.  Is there any example about midsurface extract and repair script for complex structure? Thank you.
Roy
1 - 7 of 71
    User: "tinh"
    Altair Community Member
    Updated by tinh
    I don't think there is it :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' />
    Try searching on script exchange site
    Altair Employee
    OP
    Try to search resource library in Altair site. It have nice video for advance mid surfacing techniques and tools.
    Altair Employee
    OP
    Hi RahulJ,
    Could you show me some URL link? I have not found any resource. Thank you.
    Roy
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    @Roy Duan
    Please attach your sample .hm file which you can not get good result.
    Thanks,
    Imoto
    Altair Employee
    OP
    @Roy Duan
    Thanks,
    Imoto
    Hi Imoto,
    The attachment is the model. Could you help me? Thank you.
    Roy
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    @Roy Duan
    I recommend to use the midmesh panel in 2D page.
    It just select a component, and input mesh size (2.0), and check the 'flatten connections' and hit the create button.
    You can get the below pictured result using direct midmesh panel.
    Please try it:-)
    Thanks,
    Imoto
    Altair Employee
    OP
    @Roy Duan
    Please try it:-)
    Thanks,
    Imoto
    Hi lmoto,
    I have tried the method you mentioned. There are also some problems. Is there any other good method which can be used to this model? The least time is needed along with correct midmesh.
    In addition, is there any detail explanation documents about midmesh panel?
    Roy
