Hi Clara,
The short answer to your question is that Legacy Excel connector uses OLEDB to open Excel files while Modern uses Aspose engine. The main difference between these two engines is performance and memory usage when working with large Excel files. The Modern engine uses less memory and performs better than the Legacy engine. Also, the Modern engine can open Excel files with more than 255 columns.
HTH
Mela Sarenas
Manager, QA
Altair formely Datawatch
Original Message:
Sent: 03-20-2019 10:04 AM
Subject: Legacy and Modern Excel connectors
Hello,
can anyone explain the difference between the Legacy and Modern Excel connectors? I searched for documentation but can't find any so far.
Clara
Business Analyst
IL
That's great! If possible I would like to hear about some of the other differences. So far I've found the modern version may not behave the same way as the legacy version in terms of applying formats to sources and exports as well. Am I correct about this? I say this in a hopeful manner, I like what I'm seeing.
------Original Message------
Hi Clara,
HTH
Mela Sarenas
Manager, QA
Oh the Modern and Legacy Excel engines are for bringing in Excel files. In addition to performance and bringing in 255 columns using the Modern engine, older versions of Excel (Excel 95 .xls) can only be opened using Legacy. Modern engine supports Excel .xls if it is in 97-2003 workbook format.That's great! If possible I would like to hear about some of the other differences. So far I've found the modern version may not behave the same way as the legacy version in terms of applying formats to sources and exports as well. Am I correct about this? I say this in a hopeful manner, I like what I'm seeing.
Hi Clara,
HTH
Mela Sarenas
Manager, QA
As for applying formats and exporting, the Excel engines does not apply. If you see problems in formatting and exporting to Excel, we would like to know it.
Thanks.
Mela Sarenas
Software Quality Manager
Datawatch Corporation
Bedford MA
+ 1.800.445.3311
Original Message:
Sent: 03-21-2019 10:56 AM
Hi Clara,
HTH
Mela Sarenas
Manager, QA
HTH
Mela Sarenas
Manager, QA
Original Message:
Hello,
Clara
Business Analyst
IL
HTH
Mela Sarenas
Manager, QA
Original Message:
Hello,
Clara
Business Analyst
IL
