Hi Clara,The short answer to your question is that Legacy Excel connector uses OLEDB to open Excel files while Modern uses Aspose engine. The main difference between these two engines is performance and memory usage when working with large Excel files. The Modern engine uses less memory and performs better than the Legacy engine. Also, the Modern engine can open Excel files with more than 255 columns.HTH------------------------------Mela SarenasManager, QAAltair formely Datawatch-------------------------------------------------------------------------Original Message:Sent: 03-20-2019 10:04 AMFrom: Clara BonaccorsiSubject: Legacy and Modern Excel connectorsHello,can anyone explain the difference between the Legacy and Modern Excel connectors? I searched for documentation but can't find any so far.------------------------------ClaraBusiness AnalystIL------------------------------"
That's great! If possible I would like to hear about some of the other differences. So far I've found the modern version may not behave the same way as the legacy version in terms of applying formats to sources and exports as well. Am I correct about this? I say this in a hopeful manner, I like what I'm seeing.
That's great! If possible I would like to hear about some of the other differences. So far I've found the modern version may not behave the same way as the legacy version in terms of applying formats to sources and exports as well. Am I correct about this? I say this in a hopeful manner, I like what I'm seeing. ------Original Message------Hi Clara,The short answer to your question is that Legacy Excel connector uses OLEDB to open Excel files while Modern uses Aspose engine. The main difference between these two engines is performance and memory usage when working with large Excel files. The Modern engine uses less memory and performs better than the Legacy engine. Also, the Modern engine can open Excel files with more than 255 columns.HTH------------------------------Mela SarenasManager, QAAltair formely Datawatch------------------------------"
Hello:
Is Modern also best used with large .csv files?
Thanks in advance for reply.
Al
