🎉Community Raffle - Win $25
Join and Win
How to build a motorette model (2 slots, 1.5 stator tooth) in FLUX 3D context?
Yangyu SunUser: "Yangyu Sun"
Altair Community Member
Updated by Yangyu Sun
Dear Flux community,
I am now trying to build a motorette model which has no rotor and two slots and 1.5 stator tooth, please see the attached diagram for detailed information. All the parts (volume region) are stationary.
I have already finished all the building and have checked the physical, geometry and electrical circuit, nothing is wrong. But when I tried to run it (initially magnetic transient 3D then attempt to use static steady AC magnetic 3D), it cannot be solved. One thing to note: only stator and one coil are included in this model and I tried to use no mechanical setting or assign stator mechanical set (fixed) to all of the volume regions. I believe some is wrong with the physical setting but I cannot fix it and I need your help. The error code is shown below:
CMCCCE => Wrong number of orientation (1)
CMCCCE => Failed
PBCJI1 => Failed
PBCJI0 => Failed
PBEAV0 => failed
PB_FNUM1_2 => Problem while evaluating. Unable to solve the project.
PBEPVD_4 => Failed
PBEPAV_3 => Error 49, no treated error type
PBCEVL_4 => failed
PBCEVL_3 => Failed
PBERES_3 => failed
FL5RE4 => Command not executed correctly
FL5ERS => failed
FL5ERS_1 => failed
executeAlgo_c => failed
stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
Failed execution
Non managed error which has stopped solving process
at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:170)
at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:931)
at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2249)
at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:146)
at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:347)
at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2925)
at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2103)
at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2222)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:206)
at org.python.core.PyObject.__call__(PyObject.java:545)
at org.python.core.PyObject.__call__(PyObject.java:551)
at org.python.core.PyMethod.__call__(PyMethod.java:171)
at pydb$py.executeMethod$212(pydb.py:1699)
at pydb$py.call_function(pydb.py)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
at org.python.core.PyFunction.__call__(PyFunction.java:434)
at org.python.core.PyMethod.__call__(PyMethod.java:156)
at pydb$py.__call__$179(pydb.py:1470)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyBaseCode.call(PyBaseCode.java:199)
at org.python.core.PyFunction.__call__(PyFunction.java:482)
at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
at org.python.core.PyMethod.__call__(PyMethod.java:228)
at org.python.core.PyMethod.__call__(PyMethod.java:223)
at org.python.core.PyObject.invoke(PyObject.java:3715)
at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
at org.python.core.PyInstance.__call__(PyInstance.java:372)
at org.python.core.PyObject.__call__(PyObject.java:424)
at org.python.pycode._pyx7.f$0(<input>:1)
at org.python.pycode._pyx7.call_function(<input>)
at org.python.core.PyCode.call(PyCode.java:18)
at org.python.core.Py.runCode(Py.java:1625)
at org.python.core.Py.exec(Py.java:1669)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:652)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:647)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:622)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:617)
at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:662)
at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:730)
at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70)
at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111)
at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:692)
at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
Thanks for your help !!!!!
1 - 14 of 141
    asoualmiUser: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Can you share the report file and FLux project.
    Thanks.
    OP
    Hi,
    Thanks.
    The zipped file is attached. Please have a look. Another question is that do I have to have some mechanical sets in 3D context? (no mechanical set model can work in 2D static AC environment though). Thanks a lot.
    OP
    Hi,
    Thanks.
    About the report file, I cannot find it in FLUX project folder. If you can mesh the model and run it, the error code should be there. Thanks.
    Altair Employee
    Updated by asoualmi
    Thanks for sharing, I investigate and come back to you ASAP.
    OP
    BTW can you please have a look both at 3D magnetic transient and 3D steady state AC context. I need to solve the model in both environments. Thanks !
    Altair Employee
    Accepted Answer
    Updated by asoualmi
    Hi,
    I checked your Flux project; I saw that there is no boundary condition (infinite box).  I add the infinite box but when I run the project, I get the same error message. Checking the electric terminals I have some doubt, so I recreated the terminals of the solid conductor region (I use internal terminals). With these two modifications I reached to solve the project without any error message.
    Attached the Flux project ready to mesh and solve.
    The Flux versions used: Flux 2022.1.
    Thanks.
    Altair Employee
    Updated by asoualmi
    For the transient application you have the possibility to do from the application:
    Application >> convert current application
    OP
    Hi,
    Thanks.
    Thanks for you help! I think the problem is that the way I set electrical terminals was wrong. Now they are all fixed (Both transient and steady state)!
    OP
    Yes, all the problems are solved. Thanks.
    OP
    Hey Abdessamed,
    Sorry about bothering you again in this way, but I now have similar problem relating to the model I sent you yesterday. The model I shared yesterday is a simplified model with only one turn in slot, but when I build the 'real' model with 50 turns round conductors, some weird problems show up (I think something is wrong with the mesh settings but I don't know how to fix it properly). Do you have some time to help me with this? If so, I can send you the model.
    Yangyu
    Kind regards
    Altair Employee
    Updated by asoualmi
    Hey Abdessamed,
    Yangyu
    Kind regards
    Attached a PDF file about the mesh in Flux. maybe this can help. if you still get the same behavior can you share the project. Thanks.
    OP
    I have 'reasonable' knowledge about mesh in FLUX and I have been trying to fix the problem in the past day and it's killing me but I cannot fix it. So can you please help me with this. At the same time, I will have a close look at the file you sent to me.
    Some of my concerns:
    1. when I connect the end windings, I extrude (sweep) the face along the symmetry axis with the option 'build volumes and associated mesh generator', this gives some error when I mesh the model with infinite box. However, when I build the end winding region with option 'only build volumes', this model can be meshed, but takes a very very long time. What weird is  sometimes this works, sometimes it doesn't.
    2. Another concern is that, is this because I have too many mesh elements?
    3. I also tried to deactivate the aided mesh, this seems to be not very helpful.
    Thanks for your help !!!!!!!!!
    Altair Employee
    Updated by asoualmi
    I check and keep you informed.
    OP
    OK. Thanks.
