🎉Community Raffle - Win $25
Join and Win
Transfer Tires to EDEM
User: "Brian_21702"
Altair Community Member
Updated by Brian_21702
Hi experts,
I have a trouble about coupling MSMV with EDEM interface. I want to ask how to tranfer rigid tires to EDEM? Can we just transfer rigid tires to EDEM?
1 - 4 of 41
    Hello,
    I am not certain what you have selected to transfer, but what should be selected and will transfer to EDEM is graphics. Like in the example below. I hope that this helps.
    Kind regards
    Ignacio
    User: "Brian_21702"
    OP
    Hi Ignacio,
    I used the model in MV libraries. I don't see the graphic of FL, FR tire new. Do I have to import CAD to MSMV? Thank you!
    Hi Tuan,
    Yes importing a CAD file is what was done in the case shown before I believe. Then you may need to make sure that the graphic is correctly linked to the body that it should be referencing. In that case the body referenced is Wheel-left and Wheel-right respectively, which are part of the wheel body found inside the Frnt macpherson susp folder.
    User: "Brian_21702"
    OP
    Thank you for your information.
