🎉Community Raffle - Win $25
Join and Win
Problem with spin
User: "maysam"
Altair Community Member
Updated by maysam
Could anyone tell me why i get this when I use spin to extrude 2d elements to 3d elements!!?
Base point is defined at the center but the elements close to it are not spinning!!
Also do u you where i can change node tolerance? when I try to create really small mesh, it keep telling me that the mesh size is adjusted to node tolerance! I think the above mentioned problem is because of that node tolerance. I mean the 3d nodes that are smaller than the node tolerance are not being spun.
Thanks,
Maysam
1 - 3 of 31
    User: "maysam"
    OP
    Updated by maysam
    Never mind! fixed it... i was right, the problem was because of node tolerance which reducing it fixed the issue.
    it was here: at the menu bar... preferences > meshing option > node tol.
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    You have a lot of .... bad elements at center :)
    User: "maysam"
    OP
    Updated by maysam
    yup... changed it completely ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20'>
