About selecting geometric surfaces for your model
HypewMesh Question HM-1030 'Edit Model' about selecting geometry surface.
When I performed '4. Click surfs >> all' in 'Moving between model shape components', it should be highlighted in white along the contour of the model, as shown in the figure. It will be highlighted in a part that is significantly different from the contour. What is the cause of this?
Thank you.
1 - 1 of
11
Hi Kei,
In this step you are moving the surfaces to the component named 'geometry'. Here you need to move only surfaces and not mesh, since your mesh and geometry both are visible in graphics are you are getting confused.
You can hide the mesh as shown below and then proceed:
Thank You
