🎉Community Raffle - Win $25
Join and Win
Results don't converge
User: "Matt.B"
Altair Community Member
Updated by Matt.B
Hello,
For a non-linear calculation with contacts and friction, it does not converge. (see picture warning). Despite a high refinement and a high number of passes, this does nothing.
Can you help me please?
Thanks in advance.
MBimageimage
1 - 4 of 41
    User: "Gouthami Polina_22137"
    Altair Employee
    Updated by Gouthami Polina_22137
    Hi Mathis,
    what are your contact types? If you are using a separating/closing contact, SimSolid requires a initial contact, something like a hertz contact to achieve convergence.
    Please share your model. We can take a look.
    Thanks,
    Gouthami
    User: "Matt.B"
    OP
    Updated by Matt.B
    Hi Mathis,
    Thanks,
    Gouthami
    Hi,
    Attached the model.
    I'm using separating closing contacts. But, yes some areas have no initial contact.
    Moreover, I am assuming small deformations, perhaps we should go to large deformations ? It will no longer be possible to use non-linear contacts.
    Thanks
    Mathis
    User: "M. Jenaban"
    Updated by M. Jenaban
    Hi Matt,
    I am having the same issue, has this been resolved yet? I am keen to know why SimSolid 2022 results never converge with separating contacts doesn't matter how much you refine your connections and solver.
    User: "Matt.B"
    OP
    Updated by Matt.B
    Hi Matt,
    Hi,
    The issue has not been resolved.
    No initial contact on some areas + hypothesis of small deformations seem to be fatal for the convergence.
    Good Luck
