Help with error 14
Hi i am trying to setup a problem involving a turbine blade where the surface of the component is being assigned non design and the internal is part of the design region. I have setup the problem similar to a previous case which converged successfully but I am having trouble locating the issue for this trial. any help addressing the issue will be much appreciated. I have attached the hypermesh file.
