Predefined userprofile
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello there,
I'm currently dealing with an issue regarding userprofiles window which appears directly after start of program Hypermesh (version 2017.2).
When I predefine i.e. 'Optistruct' as a solver and deselect 'Always show on start-up', this choice is not saved. When I close and re-run the HM, the same window will appear.
Is there an *.tcl script where I can predefine: default option Optistruct plus do not show this window again, please? Where are these user-predefined options stored?
Do I need rights for full control somewhere?
I've spend more than few hours on this topic, went through userprofiles.tcl, UserProfilesDialog.tcl, userprofilesmanager.tcl.
Any hint is more than welcome. Thank you in advance.
1 - 4 of 41
    User: "vipin_22401"
    Altair Community Member
    Updated by vipin_22401
    Usually it works. Try deleting hmsettings,hmmenu files in your working directory(by default my documents)  and restart hm.
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi,
    Deleting those files usually helps, Or you can write a .bat files like below:
    'C:/Program Files/Altair/2017.3/hm/bin/win64/hmopengl.exe' -nouserprofiledialog -uOptiStruct
    Search HyperMesh Startup Options in Altair Connect or in Help doc for more info.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Hi,
    'C:/Program Files/Altair/2017.3/hw/bin/win64/hmopengl.exe' -nouserprofiledialog -uOptiStruct
    Normally, the executable 'hmopengl.exe' is in ../hm/... not ../hw/..
    Altair Employee
    OP
    Thank you guys very much. Adding ' -nouserprofiledialog -uOptiStruct' to the executable path helped. Deleting hmsettings,hmmenu is not possible due to limited rights for the Altair folder.
