Altair RISE
Nominate Yourself Now!
Automator Visual Process
User: "Janet_21505"
Altair Community Member
Updated by Janet_21505
​Having a little trouble adding a "delete file" as the final step in this very simple visual process in Automator.
  • Input file:    \\TFBDATAWATCH\Input\IB54.XLS.BANK.XYZ_SBA_PPP_Loans.xlsx
  • Rename to output file:    \\TFBDATAWATCH\DATAWATCH\OUTPUT\SBA PPP Loans &[mm]&[dd]&[yyyy]
  • Email:  SBA PPP Loans 04282020.xlsx
  • Delete SBA PPP Loans 04282020.xlsx
Visual Process
Janet Grimsley
VP, Business Intelligence
The Fauquier Bank
Warrenton VA
(540) 349-0215
1 - 7 of 71
    User: "Steve_Caiels"
    Altair Employee
    Accepted Answer
    Updated by Steve_Caiels
    Hi Janet,
    You should be able to resolve this by using an input mask on 'renamed email file' that will only pick up the renamed files. SBA*.xlsx, for example.
    However, I believe there is also a potential timing issue. As you have it, both branches will run concurrently and the second part with the email/delete may try and run before the file has been renamed.  If you have an old copy of the renamed file that you are overwriting, the old version could be sent. I assume this is unlikely with a date stamp, but it might be confusing or hide an issue in the testing stage.
    You can force the second branch to wait by adding a workflow line.
    With this additional line, the second branch will not run until the rename is complete.
    In this example, the following settings are used:
    Original File : *.xlsx
    Rename File : To SBA_ &[mm]&[dd]&[yyyy].xlsx
    New File : SBA*.xlsx
    Regards,
    Steve.
    Steve Caiels
    Professional Services
    Altair
    Original Message:
    Sent: 04-28-2020 09:21 AM
    Subject: Automator Visual Process
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "CPorthouse"
    Altair Employee
    Updated by CPorthouse
    Hi Janet,
    Regards,
    Steve.
    Steve Caiels
    Altair
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    I can't remember, but "New File" may need to exist for this to work.  In the old datapump days, all inputs had to exist before a process would kick off.  Even though the "new file" will exist by the time it gets to "Email new name", when the process entire process kicks off it does not and may prevent the process from successfully running.
    Chris Porthouse
    Senior Implementation & Integration Engineer
    Altair
    Original Message:
    Sent: 04-29-2020 05:10 AM
    Hi Janet,
    Regards,
    Steve.
    Steve Caiels
    Altair
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Mo Abdolrahim"
    Altair Employee
    Updated by Mo Abdolrahim
    Hi Janet,
    Please see the following Visual Process flow to delete the input file.  I used Database Input object, but file input can also be used, since you are not exporting data.
    Regards
    Mo
    Mahmoud Abdolrahim
    Datawatch Corporation
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Janet_21505"
    OP
    Hi Janet,
    Regards,
    Steve.
    Steve Caiels
    Altair
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Steve, this solution worked. Thanks!
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Hi Janet,
    Regards,
    Steve.
    Steve Caiels
    Altair
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Janet_21505"
    OP
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Mo, I find this approach interesting in that I can get rid of the original file in a "move".  I run into a problem with the email distribution.  It will  not allow me to attach the renamed file.
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Sent: 04-29-2020 08:06 AM
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Altair Employee
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Hi Janet,
    My first Visual Process flow diagram wasn't correct.  I realized later that you want to email a copy of the input file.
    I did not have time and test the Visual Process (it pays off to test).  As you mentioned Steve method worked fine.
    I reworked the process which is similar to Steve, except I added a hub between copy and email+delete objects.
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Sent: 04-29-2020 02:46 PM
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Janet_21505"
    OP
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    My final process looks like this.  Had to add another connector to the Delete Distribution.  Thanks to you and Steve!
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Sent: 04-29-2020 06:07 PM
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Visual Process
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
