🎉Community Raffle - Win $25
Join and Win
How to mesh surface quickly if its boundary node is not uniform
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
How to mesh surface if its boundary node is not uniform!  Using Ruled Panel is usually unsatisfying. Thanks!
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Please  try with Automesh or spline with nodes (mesh delete surface).
    Regards
    Rahul R
    Altair Employee
    OP
    Hi,
    Regards
    Rahul R
    Thanks! I use spline panel, but the boundary nodes don't mach (nodes are uniformly distributed).How to deal with this problem?
    User: "tinh"
    Updated by tinh
    Hi
    Left/right clich on the numbers till new mesh match given mesh
    Shift F3 equivalence nodes
    Secondary Automesh panel allows user to change the density along edges. Once the density matches. You  can check for free edges using Shift+F3 & if the if gap is more even you can try with F3 equivalence nodes.
    Regards
    Rahul R
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    If you need to match different element sizes, follow the below from the HyperWorks student guide,
