Error61 when trying to analyze after Optimize.
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello!
I am trying to do INSPIRE tutorials(Analyzing a Generated Shape) using 'Generating Design Concept.stmod' file but I get error 61 When analyze the model after optimize.
I run Inspire 2018.3 and changed my Run history path.
My machine specs are
Processor : Intel(R) Cire(TM) i7-7700 CPU @ 3.60GHz
Video : GeForce GTX 1050
RAM : 8GB
I did reoptimize model and reanalyze but still it doesn't work.
Please help me solve this problem..
Thanks and Best Regards.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2019
    We regret to inform you that the Student Edition license file which you received recently may not allow you to run an analysis or optimization with Inspire. We have identified the cause of the problem and kindly ask you to re-apply for a new license file.
    To speed up the approval process, please add the remark “wrong license” in the comment/note field of the license application form. We apologize for any inconvenience this may have caused.
    P.S.: If you are in a hurry you may try the following: 1. Create a back-up/copy of the license file; 2. In the original license file remove the following features (actually entire blocks):
    Inspire
    InspireStampingOneStep
    InspireMotion
    InspireBase
    InspireTopology
    InspireStatic
    InspireCasting
    Only the following features will remain in the license file:
    HyperWorksEDU
    Acufieldview
    Evolve
    HyperViewTrans
    3. Save the license file and restart Inspire.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2019
    Hi, I had the same error code. Is it likely that my error is caused by the student licence too? How do you apply for a new license?
    Thank you
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2019
    Hi Will,
    Kindly share your model.
    If you're unable to analyze the model at all then it is likely that your problem is also caused due to the student license, if that is the case then you can follow the steps mentioned in the earlier reply. Reply on this thread for further clarification.
Welcome!
Welcome!
