1 - 5 of
51
Hi Imoto,
Thank you for the vedio. How to output this workflow into hypermesh?
Roy
Hi @Roy Duan
1.Save as .pmt file from Process Studio.
2.Stat the HyperMesh.
3.View(Pulldown) -> Process Manager.
4.Select .pmt file as Load template.
Thanks,
Imoto
Hi
1) create a treectrl widget
2) create items for treectrl widget
3) write bound procs of the items
Can you do it?
