🎉Community Raffle - Win $25
Join and Win
TCL: elements linked to a node
User: "Stéphane Combet"
Altair Community Member
Updated by Stéphane Combet
Hello,
I am new to tcl.
I try to get in a list the IDs of elements linked to given nodes.
I don't understand why following commands (see attached picture) does not put any element ID as results of last command. I expected 1876489 1875679 1876470 187 5660.
Thank you!
1 - 11 of 111
    User: "Marc Arnold"
    Altair Employee
    Accepted Answer
    Updated by Marc Arnold
    Hi,
    can you try double quotes instead of single?
    Check out the help for the syntax:
    https://help.altair.com/hwdesktop/hwd/topics/reference/hm/_createmark.htm?zoom_highlight=createmark
    There are also some examples on the bottom of the page.
    A little tip:
    You see in the bottom-left corner a message how many elements are selected after the *createmark command.
    That helps me to check immediately if it's working correctly.
    Have fun with scripting!
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello @Stéphane Combet,
    In addition of Marc's proposal, you may try to use *findmark , and to find nodes attached to elements.
    Below is a video (the corresponding script can be retrieved from the comments) showing how to use it:
    https://youtu.be/t8NkIQC82Ks?si=Ye3RL0wWbk8TqRgJ
    Hope this helps,
    Michael
    OP
    Hi,
    A little tip:
    Thank you very much Marc, this was the point! double quote, not single.
    About syntax, I am sometimes in trouble with what is in the help.  For exemple on https://2021.help.altair.com/2021/hwdesktop/hwd/topics/reference/hm/_nodemarkaddtempmark.htm in the exemples there are parameters in parenthesis:
     *createmark(nodes,1) 100 101 102 103 This does not work in my case. I have to change this line coming from the online help to this:
     *createmark nodes 1 100 101 102 103 to make it works.
    Thanks for the tip by the way, really helpfull!
    OP
    Hope this helps,
    Michael
    Thank you Michael. Good point with this function findmark, but I can't get what would be the benefit in my case? Anyway it's always good to have some short code tutorial like this one, thanks again.
    Altair Employee
    you're right, there should be no added value in your case, maybe it will be more useful next time ;)
    Best Regards,
    Michael
    User: "Marc Arnold"
    Altair Employee
    To be honest, I have never used parentheses in tcl, only square brackets or curly brackets.
    If you notice strange behavior, you can check the newest documentation. Just replace the version in the link:
    https://2023.help.altair.com/2023/hwdesktop/hwd/topics/reference/hm/_nodemarkaddtempmark.htm
    There is only the correct version:
    OP
    Sorry to be so stupid, but I can't use the lists in a nice way... Syntax issues :(
    Why this leads to 9 elements selected:
    *createmark elems 1 "by node id" 20072267 20072268 20072271 20072273
    Whereas this leads to only 4 elements (those around the first node of the list $selectedNodes):
     *createmark elems 1 "by node id" $selectedNodes
    Thank you!
    Altair Employee
    Thank you!
    Hello again @Stéphane Combet ,
    you just experienced one tricky concept of *createmark ;)
    In its implementation, the command considers the output of $selectedNodes as separate arguments, and it takes only the first id of the node list
    To avoid it, every time you refer to a list in *createmark, you need to preceed it by the tcl command eval:
    eval *createmark elems 1 "by node id" $selectedNodes
    Hope this helps,
    Michael
    User: "Marc Arnold"
    Altair Employee
    Alternatively, you can write {*} in front of the variable you want to "write out":
    *createmark elems 1 "by node id" {*}$selectedNodes
    You have to check if the API expects a list or separate arguments. If you need seperate arguments and have a list variable, use {*} or the command from Michael. I guess Michael's answer is the safer choice :)
    OP
    @Michael Herve @Marc Arnold
    Thanks!
    eval does not work in my case, {*} does.
    User: "Bhavik Sheth_21143"
    Updated by Bhavik Sheth_21143
    Hi,
    Check below code to get element ID list.
    #Get attached ElementIDs of node
     #TempNodesList (Node ID list)
    hm_markclear elements 2
    hm_markclear nodes 1
     hm_createmark nodes 1 $TempNodesList
    *findmark nodes 1 1 1 elements 0 2
    set elemIDList [hm_getmark elements 2]
