🎉Community Raffle - Win $25
Join and Win
Cylindrical Joint in Optistruct
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I am trying to add a cylindrical joint between two parts and apply a moment onto one part, something similar to a Hinge
But the elements tend to collapse (expand and scale up) and not stable
I have tried Cbeam elements with torsional moment as negligable, but having the same effect
Can you let me know how to create stable joint in Optistruct
Thanks and Regards
Koti
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    could you share .fem file?
    Altair Employee
    OP
    Hello Rahul,
    I have sent a sample file
    Please check and let me know
    Regards
    Koti
    Joints option is available for Optistruct MBD analysis.Refer optistruct MBD analysis tutorial for same.You have setup simple static analysis where structure would tend to deform upon loading.
    Altair Employee
    OP
    Maybe you can use an SPC and release the DoF to realize as a cylindrical joint. For instance, a cyl joint along X axis (translates in X and revolves around X) release Dof 1 and 4. Try as a work around.
    Altair Employee
    OP
    Thank you Rahul for the time and clarification
    Will check out the MBD option and see how to best suit for my condition
    Thank you Prakash, but with SPC I don't want to restrict the surrounding parts movement
    What is the end objective of analysis?
