Hello everyone,
For defining load in fatigue can I give displacement as in input in the static load case which is defined. I need to give certain amount of displacement for 1 lac cycles which is sinusoidal in nature.
Also,how can I give this 1 lac cycles as input? Do I have to manually do it in the .csv file and import it or can I define one sine wave have some kind of repeat command which will repeat the pattern of sine wave for rest of 99999 cycles? (like what is the tab 'repeat' is in fatigue manager?)
Regards,
Bharat
