🎉Community Raffle - Win $25
Join and Win
How can I check import geometry
User: "Rui Oliveira_20895"
Altair Community Member
Updated by Rui Oliveira_20895
How can I convert into a solid , is there anyway to check where the problem is.
I've exported a million of times as a solid from Enovia but when I import to Inspire is always like this like a surface so im not able to mesh or compute.
1 - 2 of 21
    User: "GTT Adam"
    Altair Employee
    Updated by GTT Adam
    Hi Rui,
    When you export from Enovia, what file format are you exporting the geometry as?
    When exported as .x_t, .step, or .stl (to name a few), Inspire should recognize it as a solid body and be able to calculate the mass properties.
    Hope this helps!
    Adam Reid
    User: "Hakan_20716"
    Updated by Hakan_20716
    Have you checked the model you imported with the Patch tool in the Geometry menu?
