🎉Community Raffle - Win $25
Join and Win
Nearfield distribution of a large array
User: "Noocheen"
Altair Community Member
Updated by Noocheen
Hello Administrator,
I want to plot the nearfield (E-field) distribution of a large planar array (16by16 elements), when all the elements are excited with same magnitude and same phase (zero phase). Can I use the array option for creating my array or it is just for array analysis in far-field? I asked this question 23 days ago, but i haven't received any result yet.
kind regards,
Nooshin
1 - 3 of 31
    User: "Torben Voigt"
    Altair Employee
    Updated by Torben Voigt
    Hi @Nooshin ,
    I couldn't think of a reason why this shouldn't work.
    Please let me know if there are any problems.
    Best regards,
    Torben
    User: "Noocheen"
    OP
    Updated by Noocheen
    Hi @Nooshin ,
    Best regards,
    Torben
    Hello Torben,
    I spent plenty of time to obtain the nearfield E-field distribution of my array by using either the periodic boundary condition or finite array option in Feko. These are the issues that I've faced so far:
    1. I used periodic boundary condition for my design based on the procedure mentioned here:
    https://altairuniversity.com/learning-library/feko-example-video-series-a-16-periodic-boundary-conditions-for-array-analysis/
    I couldn't define the number of elements in this case for calculating nearfield distribution. it seems, this option consider my structure as an infinite periodic structure. Moreover, I faced this error:
    ERROR 48382: A triangle may not lie in the plane of the periodic boundary
    2. I used finite array option, I could define the number of elements in the x-y direction, but I faced this error:
    ERROR 2331: Two triangular surface patches overlap
    I tried to solve these errors through the Altair forums' suggestions, but I wasn't successful.
    I'll appreciate it if you help me with these issues, since I spent a plenty of time on them without any desired outcomes.
    I also attached the .cfx files of both cases (periodic BC and finite array option) here:
    Altair Employee
    Hello Torben,
    Hi @Nooshin ,
    Since I don't have much time presently, please create a support case on Altair One:
    Best regards,
    Torben
