🎉Community Raffle - Win $25
Join and Win
Surface / plane intersection and move closest node of the surface to the intersection
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
i am looking for a mesh modification with TCL. Let me present my concern.
- i have a geometry i don’t want to modify.
- I want to create multiple plane at different Z location
- I want to determine closest node to the intersection surface / plane and move the nodes to this intersection following the surface curve.
does anybody has any clue to do that with HyperMesh functions ?
thanks in advance
best regards
1 - 5 of 51
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Could you show some screenshoots?
    can you do it with GUI? why you need to do it by TCL?
    Altair Employee
    OP
    Sorry, I didn't see you replied me.
    I don't want to use the GUI, only TCL to do it automatically.
    I took another way that is to calculate the min distance between nodes on lines and the objective.
    But, I am stick on the node selection :
    set Line_Peau_Sup_Milieu ' 1 5 135 150'
    eval *createmark nodes 1 'by lines' $Line_Peau_Sup_Milieu
    Hypermesh does not found any node.
    Do you have an advise. I don't see ma mistake.
    Thanks a lot
    Best Regards
    Altair Employee
    OP
    I also tested without success :
    set Line_Peau_Sup_Milieu {1 5 135 150}
    User: "tinh"
    Updated by tinh
    Should be
    eval *createmark nodes 1 {'by lines'} $Line_Peau_Sup_Milieu
    Altair Employee
    OP
    Thanks a lot. I will test !
