Imposible SICCG Solution
Hi!
Someone can help me with this problem?
Solution of linear system by SICCG impossible
The solving process has probably not correctly converged
Thank you Farid Zidat,
This is the same primary coil's step file solved individually:
And it's also taken into account that distance in geometry options, but I think that you'd adviced to create the insulation face to have the surety not to occur any short-cut, right?
If you want to check it, you've got the STEP file down below.
Did you have solved propertly using Mumps instead of ICCG? Not to me:
CECUVG => Determinant du jacobien nul
CECUVW_1 => Failed
CECUVW => Failed
CE2UVW => failed
DAV2OC_1 => failed
FL5ELE_1_1 => Error generating finite elements
FL5ELE_1 => Failed
PBCMDO => Failed
PBFNUM => Problem while evaluating. Impossible to solve problem.
PBERES_3 => failed
FL5RE4 => Command not executed correctly
FL5ERS => failed
FL5ERS_1 => failed
executeAlgo_c => failed
stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
Failed execution
at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:153)
at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:883)
at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2142)
at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145)
at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:302)
at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2794)
at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:1972)
at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2091)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:526)
at org.python.core.PyObject.__call__(PyObject.java:532)
at org.python.core.PyMethod.__call__(PyMethod.java:171)
at pydb$py.executeMethod$200(pydb.py:1569)
at pydb$py.call_function(pydb.py)
at org.python.core.PyTableCode.call(PyTableCode.java:167)
at org.python.core.PyBaseCode.call(PyBaseCode.java:170)
at org.python.core.PyFunction.__call__(PyFunction.java:434)
at org.python.core.PyMethod.__call__(PyMethod.java:156)
at pydb$py.__call__$167(pydb.py:1342)
at org.python.core.PyBaseCode.call(PyBaseCode.java:307)
at org.python.core.PyBaseCode.call(PyBaseCode.java:198)
at org.python.core.PyFunction.__call__(PyFunction.java:482)
at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
at org.python.core.PyMethod.__call__(PyMethod.java:228)
at org.python.core.PyMethod.__call__(PyMethod.java:223)
at org.python.core.PyObject.invoke(PyObject.java:3697)
at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
at org.python.core.PyInstance.__call__(PyInstance.java:372)
at org.python.core.PyObject.__call__(PyObject.java:405)
at org.python.pycode._pyx31.f$0(<input>:1)
at org.python.pycode._pyx31.call_function(<input>)
at org.python.core.PyCode.call(PyCode.java:18)
at org.python.core.Py.runCode(Py.java:1398)
at org.python.core.Py.exec(Py.java:1442)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593)
at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638)
at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:706)
at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(Unknown Source)
at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(Unknown Source)
at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:690)
at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
Thanks for your help,
Andoni
Hello;
Can you please try to use MUMPs Instead of ICCG, to modefy the solving options, please go to Solving menu, and then solving options.
However, I think your Flux project is not well defined. There is no magnetic circuit for instance. It can be the case, but if it is, I invite you te create a insulation face region between the green block and the winding.
The same thing for the coil, as it is defined, Flux will consider the coil as a block with only one turn, in this case also, you should create an insulation face region between each turn to the other.
Best regards
